EBCM Wiring Connector
Old Feb 13, 2018 | 8:33 PM
Brennan Webb's Avatar
Default EBCM Wiring Connector
So here is one for you guys...
2005 Express 3500 2WD 8cyl 6L (JL4) with ACTIVE BRAKE CONTROL
I get an ABS light pop up and I start digging the web for possibilities. Start inspecting around the EBCM (electronic brake control module) and notice right off the bat a seriously damaged EBCM connector. The male side. It looks like someone tried to pry this off before. The actual EBCM female side looks fine. Anyone know part #, cost, source?
Broken male EBCM connector housing.
Female EBCM with active brake control
Old Feb 13, 2018 | 8:45 PM
Hey that looks just like mine. Smashed. It's mounted on the frame, right? Where it's vulnerable to flying debris. Dumb design if you ask me.
Luckily I don't get an ABS light, but I inquired with GM about fixing it. They told me I would have to replace the entire harness. If I were you, I would try to repair it. That or find one at the junkyard.
