eng-1 fuse keeps blowing
Old Sep 16, 2018 | 2:05 PM
  #11
kevinkpk's Avatar
Replace the ignition switch.
Old Sep 16, 2018 | 2:12 PM
  #12
rubberpanman's Avatar
Originally Posted by geo1
And, what year,etc. is the vehicle,I'll get in the book, otherwise, AutoZone has many electrical diagrams,they and all data are same,the latter is a paid for service,much more info
It is a 2000 chevy express 3500 with 5.7 engine
Old Sep 16, 2018 | 2:21 PM
  #13
geo1's Avatar
Also,that is fuel pump relay power, disconnect?
Old Sep 16, 2018 | 2:28 PM
  #14
It's the fuel pump relay under the hood and it is disconnected.
Old Sep 16, 2018 | 2:30 PM
  #15
When the key is on it says check gages and the battery light is on.
Old Sep 16, 2018 | 3:00 PM
  #16
geo1's Avatar
Last post,key on,normal,looking further,that fuse powers relay center,so back to pulling relays,or inspecting wires leaving relay center,and the sensors you mentioned above,power comes from pcm,so the problem is before that, except o2 heater circuit
Old Sep 16, 2018 | 3:09 PM
  #17
It sounds possible. When I hit the pothole the van cut off and I had a hard time controlling the vehicle.
Old Sep 16, 2018 | 4:59 PM
  #18
geo1's Avatar
Can't find in book,does that 5.7 have a oil pressure sending unit on side of block,3 wire connector, disconnect that for a test,on older models it's tied into fuel pump,12v is there,and if it internally grounds, problem
Old Sep 16, 2018 | 5:56 PM
  #19
The one I found is on the back of engine block and has one wire. I unplugged it and still the same thing.
Old Sep 19, 2018 | 2:31 PM
  #20
Alright, today my van is cranking up no problem. I think some wiring got wet some how. I put a new hose clamp on radiator in case it is leaking under pressure. I did notice a wiring harness going into the transmission (which is a 4l80e) that is leaking fluid into the electrical connector. It's possible that the plug dried out when it was disconnected.
