engine rattle
Old Oct 20, 2019 | 10:00 AM
Default engine rattle
When my engine is under load, and I press the accelerator, there is a very brief (maybe one second), faint, muffled rattle. Like a diesel engine. Especially when going uphill. It doesn't happen in P/N. Is this normal?
2013 5.3L with VVT
(71,000km/44,000mi)
Old Oct 20, 2019 | 8:22 PM
johnt365's Avatar
Few questions:
1. Has it always done this? if not, when did it change?
2. Have you had or done any work on it lately?
My van was making a rattle like this. It would happen at a specific RPM under load. My first thought was valve clatter or pre-detonation so I put in the high octane fuel with a booster additive but no change. I checked the timing and while the dog house was off drove around and listened.
I started touching everything in sight and turns out the noise was a loose A/C bracket bolt. I guess the previous owners mechanic forgot to tighten it. At a certain RPM the harmonics were just right and drove me crazy.
Just a possibility... could be something loose.
Good luck
John
Old Oct 20, 2019 | 9:54 PM
1. Hard to say. I've been driving my van a lot more than usual lately. It might be a new problem, or it could just be that I have become more attuned to its sounds over time.
2. The only work to the engine I've done during my ownership (last 12,000 mi), is replacing the oil + filter, air cleaner and coolant. None of them lately.
I think if there were a loose part related to RPM, I would also hear it in Park or Neutral, as well as while decelerating. The engine doesn't vibrate a great deal either.
Old Oct 24, 2019 | 8:19 PM
SteveROntario's Avatar
Consider taking off your AC belt and seeing if that helps. It could be A/C slugging which is described in GMC 03-01-38-019a.
Old Oct 24, 2019 | 11:36 PM
the bulletin applies to vans from 2002 - 2004
itrustno1
Jan 16, 2014 5:36 PM
92astro
Jan 4, 2009 10:05 PM
DAYMAN
Jul 9, 2007 7:12 AM
Bob Vaughn
Jun 28, 2007 9:32 AM
