Engine shut down on freeway.
Old Sep 5, 2024 | 6:32 PM
Jamboree 07's Avatar
Default Engine shut down on freeway.
Hi
In my 2007 Express Van 3500 with no warning going 60 mph the engine shut down. While I was coasting with no brakes I put it in neutral and it started right up. This happened once before when I was backing up and it shut down and started right up again. Now I am nervous about driving it and looking for any advice.
Thank you
Old Sep 5, 2024 | 8:45 PM
BurntClutch's Avatar
Any lights on the dash? Any trouble codes? Did it hesitate or stumble beforehand?
Maybe something is grounding or shorting out causing it to quit?
Old Sep 5, 2024 | 8:56 PM
Hi
no lights, no code and no hesitation. No loss of power before. Engine just stopped
Old Sep 5, 2024 | 8:58 PM
After shifting to neutral it started right up while still moving 40 mph.
Old Sep 7, 2024 | 9:28 PM
Originally Posted by Jamboree 07
Hi
I would check your ignition switch wiring. That sounds like something is disconnecting or grounding out intermittently. Maybe something is messed up near the ECU?
Old Sep 8, 2024 | 1:05 PM
Hi
I bought a OBD 2 to check any trouble codes. There were none to be found. I will check the ground, but if it was a ground I would think it would be happening more often. I will try to see if there are any loose wires on the ignition switch.
Thanks
CharlzB.
Sep 25, 2020 9:24 AM
cherylnmike
Traverse
Jun 14, 2018 6:29 AM
nolachevy84
Oct 15, 2017 9:24 PM
gamingglory
Jul 29, 2017 4:10 PM
KCC
Apr 9, 2011 9:26 AM
