Express 3500 Extended Passenger Towing Mirrors
Apologies if this isn't the right place to ask this question, I could not find a parts specific folder on the "Express & G-Series Vans" page.
I am looking for powered/heated/extended towing mirrors for my 2015 Express 3500 2LS Extended with OE # GM 15227418 and GM 15227437; the only ones I can find are from 1A Auto and a pair from Velvac that are super expensive. Anyone out there have any suggestions? Thank you.
I did find this direct OEM replacement option on eBay at $384/pr.: https://www.ebay.com/itm/Towing-Mirr...w/372250196465
For those interested and, with deep pockets, the Velvac part numbers are #715917 for the non-turn signal integrated and non-heated pair and #716349 (black) for the integrated and heated pair at $1040.70 and $1321.95 respectively.
v/r
haznavy
v/r
haznavy
haznavy,
If you pick up the eBay version, please share your experience. I wish there was a powered extendable/retractable option... I haven't found one, anyway. Most of the tow mirrors that clip or stick onto the OEM mirrors are junk, but that's all I've found without making a semi-permanent change to my van. I've debated buying the same ones that you shared from eBay, and then just plan to swap them out based on how I'm using the van (but that sounds like a pain).
GatorHawk24,
I am going to purchase the ones from eBay and will let you know. If they work out, I will have the SafetyVan side-view convex mirrors up for sale if you are interested.
New Towing Mirrors Installed
If anyone needs new towing mirrors, I would endorse these. For anyone who wants to replace their smaller OEM mirrors, I have two in very good condition for $35 per mirror; also still have 10 Safety Van seats for $400.
Before
After
I am glad to finally see pictures of these installed. If you get a chance post a few more. Maybe a few from the drivers seat too. Then the rest of us can explore the idea more thoroughly. If I pick up a trailer, which I may if I come across the right deal while I have cash in my pocket, I will likely buy these. For all practicality, I would assume it would be best just to swap the mirrors when you tow. It's only fifteen minutes of work. Otherwise you run the risk of clipping your mirrors in regular usage. If I was you, I would keep the old mirrors. Your preferences are different than mine however.
For as common as our vans are, I am very disappointed that there are no after market mirrors that simply slide out in extension like are available for Silverado's.
More photos
