Express composite headlight adjustment.
Old Dec 17, 2019 | 7:20 PM
Muddy Waters's Avatar
Default Express composite headlight adjustment.
On a 2011 with the composite headlights where the high and low bulbs are separate, I can adjust the headlights vertically with the top screw, but is there anything that adjusts them horizontally?
Also, as a non important side note, can the high beams be adjusted independently from the low beams within the composite housing?
Old Dec 20, 2019 | 12:49 AM
dberladyn's Avatar
Without looking, I doubt that they are adjustable in the way that you want, otherwise the adjustment would be obvious. They are formed to approved specifications and not meant for separate adjustment. At least I would think that that would be the case.
Old Dec 21, 2019 | 8:49 AM
Yeah, I thought a separate adjustment within the housing is asking for a bit much, but every car I ever had to adjust the headlights on you could adjust it up and down as well as side to side... and I just don't see where is the side to side adjustment on my Express?
Old Feb 10, 2021 | 8:36 PM
a1ndrew's Avatar
This style of headlights are only adjusted vertically. I got the same issue. More importantly my headlights need adjusting and I cannot find any alginment process for adjusting distance. How far should the adjustment be made from a reflective surface (30, 40 feet). How high off the ground at the required distance do I need to set the high beams. I have looked every where and I cannot locate the adjustment requirements. HELP
Old Feb 11, 2021 | 12:01 AM
Triaged's Avatar
Scroll to the endhttps://www.bar.ca.gov/pdf/Lamp_Handbook_9.3.15.pdf
Old Feb 11, 2021 | 8:03 AM
a1ndrew's Avatar
Default Awesome response
Originally Posted by Triaged
Just what I needed. This info should be available and easily accessible to the public. thx again
Txtintman
Mar 13, 2018 3:06 PM
warf1955
Oct 24, 2015 6:16 PM
hawkeye1
Nov 2, 2012 9:49 AM
BigDawg
Uplander
Jan 30, 2012 2:42 PM
s34n
Feb 24, 2010 10:10 AM
