express rear rotors
express rear rotors
I'm replacing rear brakes and rotors on a 2005 express 2500. No problem removing the caliper but I cannot remove the rotors. I don't think the parking brake is the problem because wheel moves when it is released. Am I missing something? I can't remove both left and right.
Thanks for any help you can give me.
mike
mike
1. is there an adjustment starwheel for the emergency brake? This is the type with the parking brake cable attached to the rear caliper or the kind with mini-shoes inside the rotor on the hub?
2. the rotor was may be stuck on the hub from rust. a swift wack with a hammer(on the hat of the rotor not the rotor surface) should free it up.
ttfo
March 24th, 2011 2:19 PM
cheyenne
September 22nd, 2010 2:57 PM
knucklebust
January 9th, 2010 8:39 AM
harleynut
July 10th, 2007 9:15 PM
