Express2500 4.8l low compression
Old Nov 13, 2020 | 7:25 PM
CMartinez's Avatar
Default Express2500 4.8l low compression
Today my express started to misfire on multiple cylinders primarily #6 and # 8 so I checked the compression and had 0psi of compression in cylinder 6. My engine only has 210000 miles. Are these engines that ****ty I thought the last was suppose to be very reliable. My question is are the valves know to prematurely fail ?
Old Nov 14, 2020 | 2:18 AM
I would never buy a 3/4t van with a 4.8L engine.
Old Nov 14, 2020 | 8:02 AM
CMartinez's Avatar
why not give some details as to why might help out someone here? Thanks
Old Nov 14, 2020 | 7:52 PM
possible camshaft problem also. what were the compression numbers on the other cylinders?
the next possible steps imo would be:
-leak down test to determine where the loss is from,,,,intake, exhaust, headgasket, rings
-vacuum gauge to see if its a valve problem
-remove valve cover....crank it over and watch for rocker arm movement
Old Nov 14, 2020 | 7:55 PM
CMartinez's Avatar
I decided to buy a whole lower mileage engine and go from there
Old Nov 15, 2020 | 12:55 AM
put a 6 liter in it
Frank Leal
Aug 20, 2024 8:21 PM
Rob G
Oct 17, 2012 9:45 PM
dtsman
Oct 2, 2012 12:07 AM
TahoeMatt
11
Feb 6, 2012 7:15 PM
adambraap
Jan 28, 2007 9:58 PM
