flushed brakes 2015 - now the fluid is green - ?
Old Mar 24, 2019 | 5:38 PM
tbb2's Avatar
15 Year Member
Default flushed brakes 2015 - now the fluid is green - ?
I flushed the brake lines of this 2003 (purchased used) van in the beginning of 2015 @ 61788 miles.
Doing recent brake work, at 67645 miles, I notice the fluid in the reservoir is green.
When I flushed the fluid out in 2015 it was a black tea color.
I used Valvoline DOT 3/4 Brake Fluid to do the flush.
I see in the maintenance scheduled I put together, fluid should be changed every 30k or 24 months. 24 months - really?
I do low speed, short distance, driving and am surprised that flushing the brakes every 24 months would be needed. I can see brake fluid getting darker ... but green?
Why would light golden brake fluid turn green?
Old Mar 24, 2019 | 8:38 PM
oilcanhenry's Avatar
Should be able to go out 3 to five years on a brake fluid change. It all depends on how much mositure is in the system. They sell a kit for that, so you will know if your system is too high in H20, which is corrosive, since DOT 3/4 brake fluid is hydroscopic to begin with.
