Frame vin stamp?
Hi,
I know my older 84 k1500 pickup has it's vin partially stamped on the frame on the passenger side, is there a vin stamped on the frame of an 05 express van? I heard there wasn't, and I might be doing a frame swap possibly and don't want mismatched numbers.
When or if you do a frame swap, be sure to document the purchase transaction. Signed purchase receipts, frame number, sellers address etc. Quite a few states require a duplicate (frame) VIN when registering a used vehicle for the first time. If the frame VIN doesn't match the body VIN, questions get asked and registrations are refused.
Right, but my question is, is the vin located on the frame at all? I seem to have read a thead that express vans don't have the frames listed with the vins, so there is no frame identification paperwork needed, is this true? If not, where is the location of the vin?
My van is an 05, in 03 a major change to the chassis happened, so I don't know if the 96-02 are the same.
There was a sticker covering the first 4 digits of the vin, and they were almost intelligible because of it, but the rest of the vin matched.
Note: there is a sticker under the cab behind the front driver side door, there are a number of things on this sticker, none of them seem to be related to the vin number at all, but rather reflect internal GM labelling and stock info.
There is also a number stamped into the cab mount behind the front door, driver side, parallel to the actual vin on the passenger side: this number doesn't appear to be related to the vin number, either. Disregard
og52 (July 29th, 2022)
stephenstuff1
December 19th, 2016 6:21 PM
saabman
September 15th, 2011 7:16 PM
