Front springs and death wobble...
Old May 31st, 2015, 6:37 PM
  #11
yes, it is important. trying to diagnose a vehicle over the internet with the wrong description is a guessing game. the front suspension is entirely different. 1500's have coils.
good luck with that.
Old May 31st, 2015, 7:06 PM
  #12
I didn't bring up your ride height issues. pretty hard to fix it when you give the wrong information.
Old May 31st, 2015, 7:08 PM
  #13
epsmaine's Avatar
OK, whatever.
Old May 31st, 2015, 7:27 PM
  #14
I was legitimately trying to help you fix this. The 1500's have 3 leaf springs in the rear. They are prone to breaking when overloaded. This will change the ride height of the diagonally opposed wheel.
To bad you had to be a db about it.
Old May 31st, 2015, 8:17 PM
  #15
greenfire's Avatar
Originally Posted by tech2
since when do one tons use front coil springs?
Since like forever?
Old May 31st, 2015, 10:07 PM
  #16
Never seen one for this generation. Working for a chevy dealer; I've seen my share. I never be one to say I've seen it all but Check service information; it shows torsion bars. Napa doesn't show a parts lists for coils, only tb.
You got pics of a 2011, 1ton g van with front coils do you?
Old May 31st, 2015, 10:48 PM
  #17
canucklehead's Avatar
Strange. My 2002 2500 has coils. But I have never looked or noticed whether the newer vans switched to torsion bars. I thought the TB were only used on 4wd trucks or maybe the 1/2 ton vans with awd to make room for the front driveshafts....
Old May 31st, 2015, 10:57 PM
  #18
dberladyn's Avatar
I didn't know about a "death wobble" and I hope I never see it.
Old June 1st, 2015, 9:50 AM
  #19
I had an upper ball joint go really loose and when coasting it would rattle the front wheel.....I don't know about 50 mph though.....Usually a high speed wobble is tire balancing. I am with the above post about checking the whole front end for wear, and the wheels for balance too....
Old June 1st, 2015, 4:29 PM
  #20
greenfire's Avatar
2003-2015 Chevy / GMC G30/3500 Van 2wd w/ Gas Engine - Extra Heavy Duty Front Coil Spring Kit [TTC-1619] | $243.95 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts
http://www.cars.com/chevrolet/expres...pecifications/
Quick Reply: Front springs and death wobble...
