Front suspension/bump-stop height (2010 Express 2500)
Old May 23, 2020 | 9:11 PM
MrOldLude's Avatar
Default Front suspension/bump-stop height (2010 Express 2500)
Gentlemen,
2010 Express 2500. About 190k miles. I'm looking for any sort of input on what constitutes a "normal" ride-height.
Attached is what we've got going on. LCA is pretty much nudging the bump stop. Given, my rig has seen many miles, so it wouldn't surprise me if the springs have sagged. But I'm also kicking around buying a couple leveling pads to bump myself up 2" or so.
But if I'm just crutching shot-springs, maybe I should consider that instead. Anyway, my day to day use isn't for cargo or hauling (often). I've converted it into an adventure-van, and I sort of want a little more travel before I hit the stops on forest roads.
Thanks,
Old May 23, 2020 | 10:05 PM
2005 is the best I can do
Old May 23, 2020 | 10:39 PM
MrOldLude's Avatar
Hmm, thanks. Spring versus torsion. But maybe GM kept dimensions similar.
Old May 24, 2020 | 1:02 AM
the measurements should be same for springs. The only difference is that torsion bars can be adjusted.
Old May 24, 2020 | 9:02 AM
MrOldLude's Avatar
Alrighty, we're an 8600 lb GVWR. And it looks like from centerline of the pivot point to that lower edge, we're at about 3.5"
So, yeah, def some sag. Guess I'll look at springs too.
Old May 27, 2020 | 7:18 AM
funtwodrv's Avatar
If it's any help, our 2015 chassis has sat on the factory bump stop since it was new. I put a set of Sumo stops in and that raised it about a 1/2". I ended up removing them and trimming about a 1/2" off them due to the harsh ride they created. The Sumo's still make contact with the a-arm but the ride is much more tolerable.
Gary
Old May 27, 2020 | 8:05 AM
MrOldLude's Avatar
Hmm, good to know. At this rate, I might just just buy a new pair of OEM springs and do a leveling spacers.
Plus refresh some of the other parts in there. I drive forest roads from time to time, and I think I want a little more height off the stops.
Old May 27, 2020 | 10:02 PM
my bump stops touch too.
Old May 2, 2025 | 10:02 PM
datacreed's Avatar
I guess this forum doesn't get much activity My youngest son, doodle, and I are still maintaining a 2004 Express 2500 and use it extensively during Midwest summers.
I don't know much about the springs but my '04 are seemingly still doing their job. Added new shocks and bump stop this week in 2025.
Pete
2025-May-02.
jcramphorn@aol.com
Jun 29, 2020 2:44 PM
Pierre Daniel
Dec 26, 2019 12:09 PM
Mike Haley 1
Jul 3, 2018 6:33 PM
Berginc4
Jul 27, 2017 9:16 AM
kalvinklein
Sonic (Aveo)
Jun 23, 2017 10:15 AM
