fuel cut off inertia switch 2005 Express base model ?
Does my Van have a fuel cut off inertia switch ?
if so what does it look like and where is it hiding !
Thanks for the info
UPDATE: well Mr Google seems to say that Ford vans have inertia swichs but Chevy vans do not......
is Mr Google correct ?
Thanks for the info
The reason I asked is someone mentioned that they used an inertia switch as an anti theft devise to cut off fuel to the motor with a simple push -pull cable ,
I liked the idea but was not sure if we had one or what it was called !
The Ford switches that I am familiar with would cut fuel flow after the vehicle was struck. You had to push a button on the switch in the trunk to allow it to run again. Maybe switch power to the fuel pump relay if you feel that you can safely do so?
Dul
Aug 18, 2019 2:30 PM
C.J. Young
May 26, 2010 2:11 PM
