Fuel pressure
Checked my pressure today , key on goes to 60 then needle goes down after that, loses pressure. On crank it goes to 60 then idles around 52.. give it gas and it jumps up then goes below, then back to 50ish.. this normal?
Been having all kinds of issues lately so trying to check everything out , fuel pump and relay are only a few months old.
2000 5.7 express 1500
Thank you for reply.. pressure seems fine when running but when key on / engine off it rises quickly then falls to zero. When I crank it goes up to 60 quickly, then runs around 53. Engine off it quickly falls to zero. I’ve been reading this is caused by check valve in pump, regulator or injectors. I have spider injector within the intake and regulator is a part of that assembly. Might try to crimp the return line and see if it holds pressure but not loving the idea of taking intake apart for something that’s not causing me trouble. Starts fine and runs fine now thank goodness
Did check my 2002 Yukon with the 5.3 and it does hold pressure on key off
my short and long fuel trims are within spec, seems to be +\_~ 3% in both banks
would there be any reason for the fuel pump not to have a check valve?
chevyman86
Nov 13, 2010 8:08 AM
cams 98 silverado
Nov 16, 2009 11:00 PM
