G-20 headlight issue
Old Dec 10, 2017 | 5:59 PM
jimmydriver's Avatar
Default G-20 headlight issue
I have a 1988 G-20 van with dual headlights. Today after I changed the upper headlight on the drivers side it gets dim when I put the brights on. Anyone have a clue why?
Old Dec 10, 2017 | 6:07 PM
StanVan's Avatar
15 Year Member
You bought a bad one? It does happen. You might check the plug for corrosion. But usually if it's corroded, it will work or it won't.
Old Dec 10, 2017 | 9:57 PM
canucklehead's Avatar
bad ground can steal voltage. Check all the connections from the relay forward.
Old Dec 12, 2017 | 11:27 PM
I have no idea where the headlight relay is.
Old Mar 18, 2018 | 1:53 AM
ThroatwarblerMangrove's Avatar
IFAIK, none of the G vans from the 70s to 1995 had a headlight relay. None of mine did until I rewired the lights (on my '79) and added 2 of them.
I would suspect a bad bulb, connector, or ground wire. The connector or ground wire could have been marginal before you touched anything, and moving things around could have finished them off.
I have found the driver side headlights have more problems with connectors than the passenger side, possibly because they are very close to the battery and the acidic vapors it generates.
