G10 van stops running
Old June 14th, 2019, 10:04 PM
  #11
Rick Taylor's Avatar
Thanks. It looks like the guy who installed my engine got around the issue of a 94 engine having the fuel pump in the tank by installing an inline pump. I took the fuel hose off of the filter and a couple drops os gas came out. Than I moved it around with some pliers and a stream of gas came out. Looks like the filter had a blockage. I'm going to run it tomorrow to see if that was the issue. The 12 volts to run the pump comes from some relay I don't recognize. (Picture). I'm also going to measure the voltage at this relay to see if it stops producing 12 volts when it dies.
Old June 15th, 2019, 2:50 PM
  #12
I'm here for the party
Irish_alley's Avatar
can you still hear the fuel pump when the engine dies?
Old June 21st, 2019, 8:57 AM
  #13
Yes, I tried it again today but same issue, thinking of trying it without the fuel filter.
Old June 21st, 2019, 9:38 PM
  #14
wouldnt do that just in case theres junk in the line and it reaches the carb. have you tried to manually open the throttle with the air cleaner off to see if you see fuel spraying out.
Old June 22nd, 2019, 12:11 AM
  #15
canucklehead's Avatar
Are you trying to draw fuel from the tank through a non working in tank pump? Perhaps it is restricting you, and building up a vacuum in the line which takes that 15 mins to bleed off.
Is there a work around to remove the factory pump from the equation?
Old June 23rd, 2019, 10:46 AM
  #16
That's a good idea, I'll try that, thanks.
Old June 23rd, 2019, 10:49 AM
  #17
The original engine had the fuel pump attached, looks like I need to drain the tank and clean it out or replace it?
Old June 23rd, 2019, 5:24 PM
  #18
i dont see that really solving anything. the pump may still be pumping but you need to verify how much fuel its pumping when the engine stops
Old June 23rd, 2019, 6:11 PM
  #19
Well the pressure drops to zero but the pump is still running and the engine slowly dies as it uses the gas that is in the carb.
