How to adjust throttle position sensor?
I have a '95 Express 1500 van, and I'm still having idle issues (I have another thread on it...can be found here https://chevroletforum.com/forum/exp...er-high-41200/ ). I have put the vehicle on a diagnostic computer a few times, each time the code points to the TPS. I have replaced it, and seem to be encountering some conflicting information. I have read that this motor does not have an adjustment for idle speed, but then I find some things that talk about adjusting the TPS.
The part has a "rod" sticking out, with a plastic or hard rubber tip on it. When I turn it out, it sort of "clicks" into place what seems like every half-turn. We have been chasing this problem for what seems like forever, and we have limited resources and can not just keep buying parts all ***** nilly...
Please help!!
ANY advice will be greatly appreciated.
-Josh
Please help!!
-Josh
What you're describing doesn't sound like the TPS. Are you looking at the IAC valve with four wires at the electrical connector?
![](http://images.whisystems.com/smartpages/partinfo_resize/DUS/217-437.jpg)
If so, try zeroing it by turning the key off and then disconnecting the cable from the battery negative terminal for a few minutes. Be sure to unlock the radio first if your radio is one of those that can be theft-locked.
As far as the TPS goes, if it's 22, you may want to read the ongoing thread https://chevroletforum.com/forum/sil...15/#post177516.
Equinox Owner
January 4th, 2022 11:45 AM
ironcy
April 25th, 2007 4:21 PM
