How do I change front turn signals???
I'm trying to change the front turn lights on a 2005 Chevy Express van, I was wondering if anyone had any insight as to how to do it? It's quite frusterating and I'm not ready to take it in to the dealer and pay for it. Anyone know how???
RE: How do I change front turn signals???
You need to pop out the entire housing. Use a long flat screw driver and push-in the clip between the gap of the fender and the housing at the corner closer to the wheel well and pull it straight out. You will then see two connectors, one for the blinker/parking and the other is for parking. Twist the connector and replace the burned out bulb.
Very easy job ...
Very easy job ...
Changing front turn signal bulbs in 2006 Express van
I have attached photos to see how the press-in clip holds the outer edge of the light housing and how it is a simple twist of the bulb receptacle.
The bulb base has grooves which press in to the bulb receptacle and kiind of snap in.
Feel freen to send me an email at John@MitchellSell.com if you have questions.
Manor_Mullet
April 28th, 2008 2:13 PM
boothybunch
January 8th, 2007 11:13 PM
