How do I change front turn signals???
Old Feb 22, 2008 | 4:36 PM
jacobkmc's Avatar
Default How do I change front turn signals???
I'm trying to change the front turn lights on a 2005 Chevy Express van, I was wondering if anyone had any insight as to how to do it? It's quite frusterating and I'm not ready to take it in to the dealer and pay for it. Anyone know how???
Old Feb 25, 2008 | 3:48 PM
07kastenwagen's Avatar
Default RE: How do I change front turn signals???
You need to pop out the entire housing. Use a long flat screw driver and push-in the clip between the gap of the fender and the housing at the corner closer to the wheel well and pull it straight out. You will then see two connectors, one for the blinker/parking and the other is for parking. Twist the connector and replace the burned out bulb.
Very easy job ...
Old Feb 3, 2014 | 5:11 PM
Harleyguy3342's Avatar
Default Changing front turn signal bulbs in 2006 Express van
I have attached photos to see how the press-in clip holds the outer edge of the light housing and how it is a simple twist of the bulb receptacle.
The bulb base has grooves which press in to the bulb receptacle and kiind of snap in.
Feel freen to send me an email at John@MitchellSell.com if you have questions.
Attached Thumbnails  How do I change front turn signals???-1extractlightfixture.jpg    How do I change front turn signals???-2cliponotherside.jpg    How do I change front turn signals???-3turnsignalbulbreceptacle.jpg    How do I change front turn signals???-4turnsignalbulb.jpg
danbailey
Feb 23, 2012 2:40 PM
chevy_camaro_fans
Feb 27, 2011 2:29 PM
Lobster 207
May 21, 2008 9:10 AM
Manor_Mullet
Apr 28, 2008 2:13 PM
boothybunch
Jan 8, 2007 11:13 PM
