How do i remove the hood ?
Old Jun 20, 2017 | 5:58 PM
rwitczak's Avatar
Default How do i remove the hood ?
2010 chevy express 1500
Old Jun 21, 2017 | 8:12 AM
Twscarp's Avatar
You have to remove the wiper arms, under the black plastic cover, remove the nut on the shaft (mark the shaft to reinstall in same position). Remove the black plastic air inlet grilles, a few phillips screws. Then remove the pivot nut and bolt from each hinge.
Attached Thumbnails How do i remove the hood ?-screen-shot-2017-06-21-9.07.54-am.png   How do i remove the hood ?-screen-shot-2017-06-21-9.08.39-am.png   How do i remove the hood ?-screen-shot-2017-06-21-9.09.06-am.png
Old Jun 21, 2017 | 9:12 AM
Artie1's Avatar
You can remove the hood without touching the cowl and wipers, it's just difficult access to the 13mm bolt/nut. You need one open end wrench and one ratcheting wrench.
Old Jun 21, 2017 | 11:34 AM
Twscarp's Avatar
OK Artie1, my method was basically by the book. I would definitely remove all the cowling screws (7) and unclip the plastic tabs located at the extreme ends of the cowling (total about five minutes of work). The cowlings will still be captured by the wiper arms but you can slide them around to give you more room to get to the pivot bolts. The passenger side will be wide-open, the driver's side still a little tight, but doable.
Old Jun 30, 2017 | 2:55 PM
rwitczak's Avatar
[QUOTE=rwitczak;340121]2010 chevy express 1500[/QUOTEthanks for the advice. Want to remove the hood to repaint.
