How much PAG oil do I add to the A/C system???
Old Sep 8, 2020 | 3:50 PM
Conradish006's Avatar
Default How much PAG oil do I add to the A/C system???
Greetings member! I am replacing the A/C compressor, accumulator, and orifice tube in my van. According to ProDemand, the total oil capacity of the system is 11 ounces. And the Denso OE replacement compressor comes with 8 ounces of oil in it already. However, the compressor I bought from Advance Auto Parts came with 2 ounces of oil in it. When I removed the old compressor, there was zero oil that drained out of it. Same with the accumulator, which says to drain it out, and add the amount you drained plus 2 ounces. I'm really stuck here, I have no idea how much to add, and I really don't wanna just let it be and install everything. Also, when I run my vacuum pump, will it remove the 2 ounces of oil already in the compressor?
I'd really appreciate your help, as I can't drive the van until I finish this.
Edit, I failed to mention that the old compressor has some sort of sensor on the back of it held in with a snap-ring. The new compressor has a block-off plate held in by a snap-ring, I don't think it will work unless I switch them out. Does anybody have any ideas?
Last edited by Conradish006; Sep 8, 2020 at 3:55 PM. Reason: Had to mention another detail regarding the issue posted
Old Sep 8, 2020 | 4:11 PM
kevinkpk's Avatar
Just a suggestion, only. Pull the compressor out, install the new compressor with installation instructions on pag, and refrigerant. I the new compressor says 3 onces, go with that.
Old Sep 8, 2020 | 4:34 PM
Not sure entirely what you mean?
Old Sep 8, 2020 | 5:09 PM
kevinkpk's Avatar
Evacuate the system, add whatever the system requires, be it 11 oz's or whatever Pag comes in sized can's, in other words the size of the compressor will require X pag oil. If in doubt, take it to an ac shop.
Maribel Mtnez
Sep 25, 2019 10:54 AM
44lawrence
Jun 16, 2018 12:09 PM
saltythe_saltine
Jun 24, 2016 10:07 PM
atawiz
Jun 11, 2015 2:15 PM
jxwx05
May 10, 2009 8:43 PM
