How to remove seats from 1990 G20 van?
Old Apr 12, 2015 | 6:14 PM
SurfariVan's Avatar
Default How to remove seats from 1990 G20 van?
My second row seats are 2 captains (swivel) chairs. They are each on a black metal plate that is bolted down with 4 bolts. I am trying to unbolt them but they just keep spinning. Are there nuts underneath that I need to have a friend hold? Are they not just threaded into the metal? I am not really sure where to begin unbolting the back bench seat.
Old Apr 13, 2015 | 10:12 PM
canucklehead's Avatar
I got some swivel buckets from a 1980 chevy nomad van. They were just bolt stubs that stuck out the bottom, and the nuts were removed from below.
Old Aug 19, 2019 | 2:47 PM
GwhippinG20!'s Avatar
Default 1989 Chevy G20 trail wagons van
I am trying to figure out how to take off the base plate for the middle seat in my 89 Chevy G20 van I already have the seats out and the guy I bought it from already had one base plate out but I can't figure out how to take the second one off, like I said seats are removed already!u there Is a base plate left on the floor and there isn't any bolts to remove
Old Aug 19, 2019 | 8:35 PM
StanVan's Avatar
15 Year Member
I'd start looking for welds. They sure as hell aren't taped in.
Old Aug 21, 2019 | 3:43 PM
It's not welded there is a pin you can pull on and it looks like you can rotate the plate
But no welds
Old Apr 25, 2021 | 6:50 PM
Anthony Gilliard's Avatar
Default Seat anchor
[QUOTE=SurfariVan;299544]My second row seats are 2 captains (swivel) chairs. They are each on a black metal plate that is bolted down with 4 bolts.
I'm having the same anchor problems. How do I remove them. I'm hoping you found the answer.
Old Apr 25, 2021 | 6:53 PM
I have the four bolt pattern on a round raised pyramid type anchor for my center row captain seats. But measuring the bolts doesn't match up. Is this due to the fact that they may be from a bracket?
Old Apr 27, 2021 | 3:25 AM
William Kisselstein's Avatar
The ones I have dealt with it's a regular bolt, so you need someone to hold a wrench on the top while you crank it off from the bottom.
Old Apr 27, 2021 | 8:06 PM
Default Seat anchor
removing the second row anchor for captain chairs. I finally figured it out and thank you William. I at the time didn't have a second hand. So what I did was to put vice grips on the bolts inside the bolt inside the van. This worked probably because I still had the carpet in. After getting the first anchor out and seeing how it worked, I found the much simpler way, especially if you may want to put the seats back in at sometime. You pull the pin up and hold it in the up position. I also did this with vice grips. Then I took a screwdriver and put in the square hole with the little metal piece you can see. ( Note the little metal is only being used as a guide). But I put it up against the frame of the anchor in that whole and hammered it until the anchor frame began rotate. After it stops rotating you just lift it off. There you will find the flat play the swivel base is anchored to which is were the bolts are attached to that go from inside the van to underneath. I decided to put the one I took out back in and leave them be because they keep the carpet even and you don't have to thoroughly fill in the bolt holes. Thanks again for the responses I received. Hope this helps out others.
Old Apr 28, 2021 | 2:28 AM
That probably makes sense.
A guy could fire up a mig welder and tack a couple spots on the bolts too.
