Insulation for cargo van?
Old June 6th, 2014, 8:38 PM
rags_the_dog's Avatar
Default Insulation for cargo van?
I am looking for better Insulation to keep away heat during hot outisde
so i saw Products on line called fatmat Sound deadeners/heat shield rolls
with 80 mil thick would help for away sound and heat ? i need find best one.. but i dont want any (cotton) insulation on wall cause Moisture make metal rusty..
what do y think?
100^ Rattle Trap Sound Deadener Noise Killer | FatMat Sound Control
Old June 8th, 2014, 9:53 AM
DougE's Avatar
Yikes! $2/SF! The interior surfaces of my van are painted so little chance of rust. I just bought some foam rubber and glued it to the walls with spray contact cement. Not super deluxe material but adequate and inexpensive.
Old June 8th, 2014, 10:17 AM
wgander's Avatar
Default Insulation
I was impressed with what they said about Dynmat on the Overhauling TV show. Dynamat Sound Deadening Materials=
Old June 8th, 2014, 12:30 PM
canucklehead's Avatar
Quality carpet undedrlay works good too. Not the cheap chip foam stuff, but there are other moisture resistant ones available. You will want to skin with thin plywood after.
Old June 8th, 2014, 7:35 PM
tsbrewers's Avatar
Dynamat type stuff doesn't do much for insulation, more for sound. If you want insulation, most guys are going with a product called reflectix. you can get it at lowes for pretty cheap.
Instead of the dynamat/fatmat stuff, buy a few rolls of the "peel-n-seal" stuff from lowes/home depot. What these products do is deaden the panel. So the metal doesn't vibrate and transmit sounds. You only need a little bit per panel. Then cover that with the reflectix insulation.
Do a google search for reflectix and van and peel-n-seal, you should get a bunch of hits.
Old June 8th, 2014, 8:02 PM
WaterBoyz's Avatar
This is what I used on the wife's Vibe for sound anyway. I plan to install some in the van soon. Well the roofing stuff anyway.
I'm in and out of the van so the heat does not really bother me except when stuck in going home traffic on the interstate.
Here are some before and after pics. The stuff was cheap and I even had beer leftover.
I also used some sound proofing by Roxul.
Old July 8th, 2014, 8:50 PM
I just finish Por-15 Spray on cargo floor and will ready install sound/heat mats then put new mass back carpet for front and bedrug in rear cargo floor
Por-15 Info Stop Rust with POR-15® - We Know What Permanent Means!
Auto Carpet info Auto Carpet for Car, Truck, Van - Stock Interiors
80 Mil sound/heat mats from Ebay info http://cgi.ebay.com/ws/eBayISAPI.dll...=1200331559008
bed rug info Bedrug Bedliners, Truck Bedliners, Bedrugs, Truck Bed Liners, Cargo Van Mats BedRug - Next Generation Bedliner
Old July 8th, 2014, 9:48 PM
I saw one g panel van come into the shop with hard spray foam on the walls and ceiling.
Old July 8th, 2014, 11:02 PM
Spray Foam on wall is very bad for metal wall cause Moisture look picture it from ford van
Old July 9th, 2014, 12:19 AM
can anyone with a panel van confirm that they have foam over the panels where the glass would be from factory.
I asking here....doesn't this product act as a moisture barrier?
link wouldn't open
Quick Reply: Insulation for cargo van?
