Insulation for cargo van?
Old May 10th, 2015 | 1:19 AM
  #11
street's Avatar
This dude says USEAL is better than peel n seal:
I want to insulate my van and I will be using this seal and some reflectix.
Old May 13th, 2015 | 11:28 PM
  #12
endneu913's Avatar
I've posted up in the recent spray foam thread about my experience with regular old pink fiberglass residential insulation. Tried and true for 5 years plus. I sleep in it in all weather, comfortably I may add.
Basically, split it for thinner wall, mount it with bailing wire, skin with 1/8" ply. Glue carpet on ply if desired.
Old May 13th, 2015 | 11:38 PM
  #13
dberladyn's Avatar
The Spray Foam thread, is that how it's now known as?
It's good to hear you don't have moisture issues. But personally I think it's better to use Roxul. You'll have fibreglass constantly in the air with your system no? Although you do have the advantage of weight savings, the particular Mineral Wool I used is heavy.
One thing though.. you go through all that trouble insulating, yet you left the pockets in the ribs empty. I am not against foam, I am only against the particular foam I used. I'd do the same over again, only this time I'd have used "Window and Door" foam. It's much more forgiving. I also wouldn't have sprayed the "vent".
bmusic621
January 26th, 2011 3:59 PM
scott291racing
April 28th, 2010 11:13 AM
4th Burban
March 1st, 2009 9:14 PM
4th Burban
November 7th, 2007 8:54 AM
4th Burban
November 6th, 2007 11:20 PM
Quick Reply: Insulation for cargo van?
