Jacks
#12
I think he's talking about a jack for emergency. Do you carry the floor jack around with you all the time?
#13
Ummm, ok. Full disclosure. In the back there's floor jack, bottle jack, factory jack, plug kit, full size spare (on the door), and tire pump. There's also a tool cart and jump box. I was an Eagle Scout.
#14
I used to carry a floor jack, jack stands, impact wrenches and a whack of tools just in case...probably 150lbs of stuff in the trunk. These days, I refuse (i'm to old) to fix my vehicle on the side of the road so I carry a AAA card and have it towed to my shop.
What can you fix on the side of the road anyways...change a tire, install a belt.
dberladyn (July 2nd, 2019)
#16
I also carry a lot of tools and a AAA card ,
plus my van has a full size spare if needed ,
I might bring a full size jack if I was going cross country ,
the stock jack works fine but you cannot be sure you are going to be on a firm surface and not dirt or gravel.
#19
one of the things I hate is putting lug nuts on with a air gun and not go back on torque them correctly....
this seems to be the Wal mart way !
you have no idea if they are at 50 lbs or 125 lbs
here is the proper way , loosen up a lug nut with a breaker bar , and then tighten with a torque wrench ,
if its a clicker torque wrench , stop when it clicks.
I do not like loosing up unknown lug nuts with the torque wrench as you have no idea how overtight they are ,
and its not good for the torque wrench ,
Yes this takes some time , but now you can be pretty sure that your lug wrench will get them off .......
ohhh why not take a breaker bar / proper socket and a piece of pipe with you anyway......
