looking to buy - please chime in
Old Mar 20, 2012 | 6:33 PM
ap14's Avatar
Default looking to buy - please chime in
Hi guys.
I'm going tomorrow night to see a 2004 cutaway with a 6.0 V8 in it. it has approximately 125000 miles on the clock.
I'm pretty good with cars and I have reasonable expectations when it comes to used vehicles, but I wanted to know if there are any specific problems with these vans. ConsumerReports indicates the transmission, and the electrical system as problematic, but it's always better to hear from you guys.
Thanks in advance.
a
Old Mar 21, 2012 | 9:17 AM
PitCrew's Avatar
I have a 2004 3500 6.0L cutaway van as an RV. It has a little over 62K miles. And for the most part, trouble free.
~ Factory had installed a wrong configured fuel pump (if you drove until fumes, the pump would overheat and then shut off). Replaced under warranty
~ Battery & tires replaced at 57K (6 years)
~ Idler, Bracket, & Pitman Steering Arms replaced at 58K
~ Passenger side, fwd O2 Sensor replaced at 61K
~ At 61K also experienced transmission 2-3 shift solenoid failure (Code: P0758). Turned out to be the ignition switch which was intermittent, and was on the verge of total failure. (Note that this series of vans are noted to have weak ignition switches. For 'total failure' of the ignition switch, info here GM truck bad ign. switch)).
All in all, a great truck with very little problems thus far.
Old Mar 21, 2012 | 10:28 AM
ap14's Avatar
Thank you PitCrew.
That doesn't sound scary at all. In fact it's minimal. And thanks for bringing up the ignition switch problem. Those kind of gremlins can be pretty time consuming to trace and fix.
I'm sure this truck is gonna be a bit different though, since it's a working vehicle.
Thanks again.
Old May 11, 2012 | 9:25 PM
PapaNix 07 Xpress's Avatar
Chiming in a few months late, perhaps, but here is my $.02.
Never had a cutaway, but have driven perhaps 1/2 dozen '06 on vans for work, and now own a long wheelbase passenger.
The are darn good rigs in my opinion. Mine was very low miles (37,500 when I bought) I have seen these with 600K miles (no kidding). Trans do seem to wear, eventually. Stock tires finally replaced at 70K. Replaced with OEM stock Bridgestone R265. VERY confortable ride, and awesome tread life.
Read these forums to pick up little tidbits but overall I feel Chevy hit a home run with these vans.
Nick
Farva
Jan 17, 2013 6:56 PM
jft7032
Dec 31, 2011 8:43 AM
exist12
Sep 25, 2011 3:21 PM
shipma
Aug 23, 2011 10:42 AM
adam07impala
Oct 12, 2007 1:27 PM
