Looking for OBDII pids for outside air temp, and fuel level.
I recently purchased a Veepeak OBDII module for my 2002 3500 cutaway. I also purchased the OBDFusion app to use with it. I had tried another free app, but it wasn't that good.
I have been able to get most of the parameters I want, to show in the app. I had to "dig" a little in the app for ATF temp but I found it. I'd like to get outside air temp (maybe air intake if OAT isn't available). I'd also like to get fuel tank level.
I suspect these may have to be user defined which I am not fully knowledgeable with. I have a little experience from my Scangauge II days.
Any help much appreciated.
Thanks.
Thanks.
outside air temp should be PID $1161
I have the Veepeak OBDII bluetooth plug in module and the OBD Fusion app on my phone. I can get all the parameters I am looking for on the app dashboards/display except for a couple. Fuel level (remaining in tank) and outside air temperature. If intake air temp is available, I'd take that as probably being close if not relevant to outside air temp.
The app allows me to create "user defined pids". I am looking to find the proper parameters in order to define the pids (if they're even accessible/available on a vehicle this old) and then create them within the app.
Thanks.
