Lower steering column
Old Jul 17, 2023 | 4:34 PM
jjrbus's Avatar
Default Lower steering column
Me again. I have a 2001 Chevy 3500 Express, 5.7 cab&chassis, which is now a Roadtrek RV.
I am replacing the factory radio, I removed the dash bezel with no issue but now having trouble getting it back in place. I was told to remove the 2 bolts holding the steering column up to give me a couple more inch's to work with. Is this ok to do or will I bend, damage, destroy something?
Old Jul 17, 2023 | 6:25 PM
it's fine the steering shaft is on a flexible joint but you may still want to hang it off a bungee cord or something
Old Jul 17, 2023 | 7:35 PM
jjrbus's Avatar
Many thanks. I always a bit hesitant to try something I read on the net!
Old Jul 18, 2023 | 12:24 AM
whatever you do just don't pull it. It's on a splined shaft that can slip out, and you don't want to lose the alignment
treeslayer
Nov 17, 2022 11:50 PM
gray truck
Aug 7, 2021 6:45 AM
jaymoung
Dec 18, 2011 9:33 PM
bg1977
Feb 10, 2008 6:30 PM
