My 2001 Camper Conversion Van
#102
Upgraded Van
I made the big jump this month to a much newer van. It is a 2018 Chevrolet Express with 15K miles. I have spent the last several weeks transferring everything from the old van (2001) to the newer van. It was fairly easy because Chevrolet has not changed the body style of the Express van in over 20 years. Not much new to add -- just the changeover. I will post some improvements in future posts. One of the big improvements was that this newer van had OnStar and a WiFi hotspot. Now we can check our email, download our newspapers, and keep in touch as we drive which we couldn't do before because our cell phones are fairly simple TracFones.
MiragePilot (October 21st, 2019)
#104
Thanks. I will miss the electric seats and the "Cadillac" ride of the old 2001 LT (1500), but I will have better towing and load capacities with the new 2500. Chevrolet doesn't even make the 1500 anymore. The old one had many features that I didn't need and did not use. For example: the dual monitors and VHS video system. We took the new one on its maiden camper voyage last Friday night. Everything went well and I found a few things that needed changing and upgrading. I have enjoyed following your "le Moose" postings as well as LenS and his "Green Tardis." I have borrowed or modified ideas from both of these. Keep posting!
#105
congrates on the new camper. looks good.get some used electric seats. is it black? limo tint.what engine doe's she have 4.8 does she have decent lowend grunt?
you imply the 2500 has a harsher ride than the 1500. I believe 1500 and people mover vans have softer suspension the explorer conversions certainly have softer than cargos.
how is wind at expressway speeds? w/ longer front should be an aerodynamic improvement?
#106
#107
Regarding towing, I hope your new ride has the G80 option. It's the locking differential option, and you can check if you have it by the RPO sticker on the passenger door. If you don't have it, you're stuck with one-wheel drive. It is disconcerting that with a vehicle known for towing, a majority of them don't have this important option. I, sadly, am missing it on mine.
#108
also what is the usuelle gear ratio for AWD 1500s TB.
#110
The G80 gov-loc differential is an option for RWD and AWD vans. It's the same piece of hardware.
Even without it, the traction control system is there to limit the amount of wheel spin.
Gear ratio depends on your van package, engine, transmission and towing configuration. My AWD came with 3.42:1 gears.
the Brain (November 3rd, 2019)
