My VAN 20th anniversary
Old Mar 26, 2021 | 9:46 PM
  #11
I never lose any coolant
Old Mar 29, 2021 | 9:31 AM
  #12
GeneveConversionVan's Avatar
Well,
Time to take her to the shop... any estimate of labor/parts cost? I dont see any evident leaking. Nor where her parks or smell or mark of drops anywhere I can find...
Old Mar 29, 2021 | 10:49 AM
  #13
MiragePilot's Avatar
Get under the van and look for drops of coolant collecting at the bottom of the engine, directly behind the crankshaft pulley on the front of the engine.
The coolant leaks at the intake manifold gasket will evaporate off the hot engine block while you’re driving and don’t usually puddle on the floor underneath the engine. On my van I was able to see a single drop on the bottom of the engine after everything had cooled down.
I did all the work myself, so can’t give you an estimate of the cost if you take it to a shop.
Peter
Old Mar 29, 2021 | 2:07 PM
  #14
Peter
I just took this picture. Do you believe all that stain behind the pulley is the leaked coolant?
Old Mar 29, 2021 | 2:24 PM
  #15
It looks like it to me. The area circled in blue is where I observed drops of coolant on my van. The coolant is either leaking from the water pump or the forward end of the lower intake manifold gasket.
If you remove the coolant reservoir it will give you better access to inspect for leaks around the pump and intake manifold-to-engine block mate line on the front of the engine. If you can’t see anything, then you will need to do a coolant pressure test and that will expose the leak sites.
Based on my experiences with two of these vans (same model), it were me I would plan on replacing the lower intake manifold gasket, water pump and radiator. And, since you’re in there, I replaced the coolant hoses and the thermostat too.
Peter
Old Mar 29, 2021 | 4:22 PM
  #16
Ok got it! thanks Peter!
lovevans
35
Sep 25, 2023 10:15 PM
CoronaVan
56
Nov 8, 2021 7:43 PM
VanKo
Jan 10, 2021 10:17 PM
mconrad
Jan 1, 2021 9:35 AM
OBXvan
Nov 26, 2018 8:48 PM
