Mystery hose, engine codes
Old June 19th, 2022, 1:23 PM
  #11
kevinkpk's Avatar
<edited for length>
MAF sensor isn't reading on the scanner, have you unplugged it, if not try that and see if it makes any change.
Last edited by mountainmanjoe; June 19th, 2022 at 1:32 PM. Reason: unnecessary use of quoting
Old June 20th, 2022, 8:00 PM
  #12
vdocad's Avatar
Originally Posted by kevinkpk
<edited for length>
I tested it for both Hz output and DC volts output. At idle, the HZ measurement was around 4000 Hz and increasing RPM brought it up to about 5000. Should it be more?
Also, the DC reading at idle is about 2.4v and apparently it should be around 1v. Increasing RPM moves up but not much. I sprayed isopropyl alcohol on the sensor to clean it and tomorrow will check the numbers again. Given the findings, does it look like it needs replacing?
Old June 20th, 2022, 10:43 PM
  #13
Throttle and MAF are both pegged zero. I think you have a wiring harness fault.
Old June 27th, 2022, 12:11 PM
  #14
vdocad's Avatar
Actually MAP at zero was just the scanner set to lbs instead of grams...
Old June 28th, 2022, 1:43 AM
  #15
I think you mean MAF.
Lbs is too coarse of a measurement. Try grams.
You've already started a separate topic about your MAF sensor called "MAF sensor fuse?" , so I'll answer there.
Old June 28th, 2022, 10:03 PM
  #16
Originally Posted by vdocad
I was able to reproduce the same codes, p0300 at idle and if I erase it and increase RPM, I get p0308 only... Engine starts every time with no issues, idles fine and drives fine( I think). Any ideas?
P0308 is misfire in cylinder 8, which can have many causes.
Since it's specific to one cylinder, you'll want to inspect the spark plug, and try things like swapping ignition coils and fuel injectors with another working cylinder.
when in doubt, punching your trouble codes into the website obd-codes.com provides excellent troubleshooting steps.
Old July 1st, 2022, 11:33 AM
  #17
vdocad's Avatar
Thanks for the ideas. I have been to the site you mentioned and got some good ideas.
I swapped plug, wire and coil from the cylinder next door and the problem is still there. I also verified that injector 8 is getting 12v and the repeated ground signal from the computer. I guess all that is left is swap injectors.. I thought that running the engine on carb cleaner for almost an entire can would have cleaned everything(the injector is clicking with the engine running).
Also, I don't have a way to check fuel pressure yet. Will do that when I get a gauge.
Old July 1st, 2022, 2:31 PM
  #18
vdocad's Avatar
I am afraid to ask...
Could this be the source of my problem(p0300, p0308)? That looks like a broken bolt right next to cylinder 8(left).
Old July 2nd, 2022, 11:25 PM
  #19
someone broke the exhaust manifold bolt. Leaking exhaust can skew the oxygen sensor reading, which could cause incorrect air to fuel mixture, which could cause misfire.
Old July 3rd, 2022, 12:06 PM
  #20
vdocad's Avatar
I appreciate your comment. I will order those clamps and see what happens. A lot of people have used them successfully and for $20 you can't go wrong.
Happy 4th!
Pjkoenig
August 21st, 2023 10:26 PM
Drivingmad44
May 24th, 2018 8:24 AM
CJ_03_2500HD
January 10th, 2014 8:17 PM
aubiexx
November 26th, 2012 7:29 PM
Quick Reply: Mystery hose, engine codes
