p0053 and p0054 CEL Codes after about 7 starts
Old Nov 25, 2012 | 2:31 PM
aubiexx's Avatar
Default p0053 and p0054 CEL Codes after about 7 starts
I have been trying to figure this out, and have replaced all 4 of my O2 sensors. Anyone have previous experience with these codes continuing to pop up after clearing them, and then cranking the 07 tahoe after about 7 times?
Old Nov 25, 2012 | 2:59 PM
kevinkpk's Avatar
Interesting since both heated O2 sensors are flagging resistance out of range. I'd suggest tracking down a problem in the wireing harness, i.e. routed to close to exhaust, or cut wire ect. If you have an ohmeter, I'd suggest unhooking the connection, read the resistance on both O2 sensors. I do NOT know what it should be, also these have been replaced, was this the reason for that? I assume after you replaced them, you cleared the code, and it came back?
Old Nov 25, 2012 | 8:15 PM
aubiexx's Avatar
Thanks. Yes - I have cleared the codes multiple times...same results. I have also checked any fuses I can remotely think would be related to this issue with no luck.
I can try to check with an ohmmeter when I can over the next weekend or so, but as for getting into the whole wiring harness...that's something I don't think I value to tackle.
Still looking for any other ideas or others who have had the same issue with resolve.
Thanks in advance.
Old Nov 26, 2012 | 2:38 PM
kevinkpk's Avatar
Thanks in advance.
What suggested was physically look it over as to make sure it dosen't have any melted spots, routing ect.
Old Nov 26, 2012 | 4:34 PM
+1 check the harness as far back as you can and check under the hood as rodents have been known to chew at wiring
Old Nov 26, 2012 | 7:29 PM
MDTAHOE's Avatar
Professional Mechanic
The O2 heaters are protected by a fuse. It is possible that one of the old one blew the fuse.
BrianL
Sonic (Aveo)
Feb 18, 2020 5:42 PM
deepstuff
Mar 6, 2012 9:51 AM
Skillit
Dec 20, 2010 3:21 PM
leedurr
Oct 14, 2009 4:35 AM
richiet
Sep 7, 2009 3:13 PM
