TrailBlazer 2002-2009
05 Trailblazer p0410, p0106, and p0054
Old Oct 13, 2009 | 9:55 PM
leedurr's Avatar
Default 05 Trailblazer p0410, p0106, and p0054
All three of the codes were set. I changed the O2 sensors for the p0054 codes. I know the P0106 is for the map sensor.I know P0410 is for secondary air injection. Could all of these be related to the the air system failing? I have drained water out of the lines and pump 3 times now. Does anyone have any ideas where to get the pump and solenoid valve other than the dealer. I have a feeling that the air system failure is causing more issues now. Any help would be greatful.
Old Oct 14, 2009 | 4:35 AM
leedurr's Avatar
UPDATE. Well the P0106 is being caused by a dirty throttle body which is gunked up from the moisture in the secondary air system getting back the throttle body. I will clean that today and let you yall know.
aubiexx
Nov 26, 2012 7:29 PM
deepstuff
Mar 6, 2012 9:51 AM
wolfe
Jul 25, 2011 10:37 AM
Boomin05Nox
Feb 18, 2011 3:21 AM
jbi
Jun 16, 2010 10:19 AM
