No Low beam headlights
Old Jul 11, 2019 | 11:41 PM
Mike Burkey Jr.'s Avatar
Default No Low beam headlights
Hello, I have a 1994 g20, the high beams and fog lights work fine but both of the low beam headlights do not work and nor do they have power going to them, I tested with a multimeter while they were on. Could it be a bad relay? And if so where is that located at so I could the good ol shake test and or replace it. I just received this van I am not too experienced with the electronics side of it.
Old Jul 12, 2019 | 12:00 AM
Beau Oszman's Avatar
When I get in (2-3 hours) I'll post wiring diagrams from Clymer. Separate sealed beams (side-by-side) design may be on a separate fuse.
Old Jul 12, 2019 | 2:47 AM
Ok, here's everything I got for '94 G series models
Hope something in there helps.
Old Jul 12, 2019 | 10:36 AM
Does anyone know where the daytime running lights relay would be or the fuse going to it?
Old Jul 12, 2019 | 1:49 PM
There's the basic fuse box behind brake pedal (my '93). If not there in the '94 check under driver seat. Don't know about the relay off-hand. You might have an under hood relay box also.
Old Jul 13, 2019 | 2:23 PM
Thanks you I did solve the problem, bad ground connection. Thank you for all of your help I really appreciate it and I'm sure those pictures will come in hand later
Old Jul 13, 2019 | 4:55 PM
Good to hear. Stay safe.
