No power to Knock sensors
Old Sep 21, 2025 | 4:28 PM
BluExpress's Avatar
Default No power to Knock sensors
2004 Chevy Express 3500 – 6.0L LQ4
Knock Sensor Circuit Issue (No Power at Harness Connector)
Background:
For several years I intermittently received a Knock Sensor 2 Low Circuit code. After clearing, it would often stay away for days, weeks, or even months.
Recent Repairs:
  • Installed new AC Delco knock sensors (both)
  • Installed new Ac delco knock sensor sub-harness
After completing the work, the engine idled perfectly with no codes. Once I reassembled everything (doghouse, seat, dash panels) and took the van for a test drive, the fault returned—this time for both knock sensors.
Current Issue:
Upon further inspection, I discovered there is no power at the main harness connector feeding the knock sensor sub-harness.
Request:
I’m looking for a detailed wiring diagram for the knock sensor circuit on a 2004 Chevy Express 3500 (6.0L LQ4). Specifically:
  • Power and ground sources
  • PCM pinouts related to both knock sensors
  • Any known failure points (connectors, splices, or grounds) common to this circuit
Any guidance, diagrams, or diagnostic tips would be greatly appreciated
Old Sep 21, 2025 | 9:12 PM
Triaged's Avatar
https://charm.li/Chevrolet/2004/Expr...20Diagram%206/
Try this.
jdog
Dec 10, 2024 12:11 AM
jfmorris
Aug 22, 2024 3:01 PM
Brit1945
Apr 30, 2021 1:24 AM
chevyz71_03
Sep 17, 2008 8:32 AM
lgarner
Aug 26, 2008 6:39 PM
