O2 Sensor failure 3 times
One of my O2 sensors (P0059) has failed 3 times with about 2 weeks between failures. Auto mechanic doing the work under warrenty says it's the ethanol in the gas. Definately not true since the other sensors are OK. Got an appointment with the Chevy dealer to find the problem.
I understand that these O2 sensors are just for emissions control and do not damage the engine or cause any other problem. My state doesn't do emission control testing.
My question - Why should I spend $200+ to find & correct this problem? That's a lot of money to me.
Thanks, Al
Thanks, Al
Thank you for the input. I cancelled the appointment with the Chevy dealer since the check engine light didn't come back on yet. That should save me $200+. Tomorrow I go on a 1500 mi trip, so I will try to measure the gas usage if the check engine light comes back on. By the time I return maybe there will be something for the mechanic to find & correct.
Al
Al
the only other thing that i know of an o2 sensor causing besides an "emission control malfunction" is the possibility of running lean or rich on your fuel mixture?
correct me if im wrong but i dont see that causing an engine problem..
why not change it yourself? have you changed a spark plug? thats about how hard it is, all u have to do is get it plugged in to see which one it is and autozone can do this for u
"why not change it yourself? have you changed a spark plug? thats about how hard it is, all u have to do is get it plugged in to see which one it is and autozone can do this for u".
It's been 20 years since I worked on a car because of the chip they use in the cars. Now with the Diagnostic Code Reader for OBDII Vehicles and your comment <!-- / message --><!-- sig -->I feel more confident again & DIY sounds like a great plan. Plus all comments say there would be no engine problem if I didn't get to it right away. Thanks.
the cars nowdays are actually fairly simple if you know what to look for and what to take off to get to the part you are fixing, they are like computers...just plug and play, no tuning or nuthing but troubleshooting is hard without the right equipment
tsduke
October 21st, 2009 9:52 AM
