I am getting that light coming on in my 2004 with the 6.0 for about 2 minutes after I start the van. Does it normally go out on its own like this? The manual doesn't say that it does.
Steve, I was baffled by the same issue on my 2006 with the 6.0. Oil light coming on a minute or so upon start-up despite pressure looking OK. Turns out these vans have the computer tell you when it thinks it's time to change the oil, and that's the signal. Google for the re-set key dance and I'll bet that takes care of it.
When the oil light comes on after startup for about 2 minutes, that's the oil change reminder. You can reset this by turning the ignition to run without starting it, and immediately pressing the gas pedal 3 times within the first 5 seconds. The oil light should flash to let you know that it has been reset.
When the light is flashing, that means that the oil level is low. The computer can determine this via an oil level sensor on the passenger side of the oil pan. If the light is flashing, STOP! DO NOT drive the vehicle until you have added more oil! It can cause severe damage to your engine to drive this way.
Thank you for the confirmation guys. The manual did not mention that it will turn off on its own. I'm getting the oil pan gasket changed this week so it'll get an oil change with that. I just don't have the time to keep up with things right now.
