oil pump help on 2000 express 3500
Old Feb 22, 2018 | 5:52 PM
B1uzcruzin's Avatar
Default oil pump help on 2000 express 3500
I have no oil pressure on my 3500 5.7L. Trying to find out how to change the oil pump because I am unsure. Do I only have to drop the oil pan and I will have acess to it or is it located else where in or on the motor?
Old Feb 22, 2018 | 6:22 PM
yes you have to drop the oil pan. Not sure about your van, but the crossmember might be in the way to do it in the vehicle.
Old Feb 22, 2018 | 6:39 PM
B1uzcruzin's Avatar
Ok because there isn't many videos about it so going in blind. I've looked at a couple of threads on here about it but they weren't about a 3500 it was 1500 so just wanted to make sure before I dropped the pan to realize it was somewhere else. Thank you. It died on me one day while I was driving and it was low on oil. It showed no oil pressure so put oil in and changed the oil pressure sensor hoping it was an easy fix. Do you know how much of a pain it is to change the pump by chance?
Old Feb 22, 2018 | 7:40 PM
Twscarp's Avatar
" It died on me one day while I was driving", was it making a racket when it died? Does the motor run now? Seems like the oil pump's entire life is bathed in oil and would last forever, I guess starved for oil it could get wiped out, but wouldn't the crank and rod bearings go first? It's located at the rear of the pan, the oil pick-up is attached to it.
Attached Thumbnails oil pump help on 2000 express 3500-screen-shot-2018-02-22-8.35.35-pm.png   oil pump help on 2000 express 3500-screen-shot-2018-02-22-8.36.09-pm.png   oil pump help on 2000 express 3500-screen-shot-2018-02-22-8.36.58-pm.png
