oil switch reference
Old Sep 5, 2018 | 9:23 AM
mikespain's Avatar
Default oil switch reference
Hi,
Could someone please help with the reference number for the oil switch 3 pin (that also switches the fuel pump) for a G20 1988 5.7L and the best place to order it from,as here in spain it is impossible to find out.the one removed which was damaged when previous owner removed the engine .
thanks in advance-M
Found it GM ref-25036938 which actually has 2 pins so the one that was fitted was wrong anyway
thanks for reading
Old Sep 8, 2018 | 6:27 AM
oilcanhenry's Avatar
Originally Posted by mikespain
Hi,
thanks in advance-M
thanks for reading
¿Existe essa parte que você procura?
https://www.rockauto.com/en/catalog/chevrolet,1988,g20,5.7l+350cid+v8,1046236,electric al-switch+&+relay,fuel+pump+/+circuit+opening+relay,3380
