Outside temp display?
Old October 22nd, 2018, 4:50 PM
  #11
StanVan's Avatar
I just read the O/M for the '16, and no, it cannot be enabled.
Old October 23rd, 2018, 1:10 AM
  #12
dberladyn's Avatar
I bet you that this is a Computer Program Issue. I have the Temperature, but no Compass in my DIC. I bought a compass module and the actual factory wire to run, just as the factory did, plugging it all together. If I recall right, half of my wiring was already there, I just had to add one or two wires to a harness. Completing that, I took the truck to the dealership to have the compass enabled. They spent all day on it. It had nothing to do with them, nothing to do with what I had done, it all had to do with GM Head Quarters not allowing them to re-flash the computer. They would not do it. I could have had the compass if I would have accepted having the computer flashed with software written for trucks meant to be sold and driven in the United States. However it changed something for my Canadian model. I would have gained the Compass and lost some other function, I forget what it was. Seems to me that it had to something to do with the Driving Lights. I probably should have done it because it appears you all have driving lights anyways. Maybe it was some other option I was to lose out on if I had it re-flashed that way. I forget.
I bet you that it will be the same thing with your Temperature Display. You will have to go to the dealership and have the truck flashed to a different build.
Old October 23rd, 2018, 8:43 AM
  #13
StanVan's Avatar
So what I do is to run an OBD2 Bluetooth device, feeding a cheap Android tablet running the Torque app. One of the gauges I chose was "Ambient Temperature". I don't run it all the time, because it can be a PITA to keep running if I have 4 or 5 stops in an outing. But I do use it on road trips.
Old October 23rd, 2018, 9:43 AM
  #14
GatorHawk24's Avatar
I looked at my van last night, and I can confirm what StanVan said about not being able to enable/disable the outside temperature via the DIC... Curiosity got the best of me, and I remembered when I was researching vans that the outside temp was an "option." So I went to the Chevrolet Build & Price website, and even on a 2019, outside temp is an option! Why this isn't standard equipment is beyond my comprehension... especially for the $10 up-charge. I'm sure if you can figure out where to plug in the wires, you'll have an outside temp display.
Last edited by GatorHawk24; October 23rd, 2018 at 9:45 AM. Reason: Picture didn't load correctly.
Old October 23rd, 2018, 12:34 PM
  #15
silent_20's Avatar
The weird part is that it has the sensor install from factory. I don't know if the other end is plug in. I will check when I get home if I have any type of voltage coming from the plug.
Old October 24th, 2018, 2:22 PM
  #16
Hmm, maybe dberladyn is on to something with the computer re-flash... which makes the $10 up-charge even more ridiculous...
Old October 24th, 2018, 2:50 PM
  #17
StanVan's Avatar
And that means we won't get it if GM won't allow the flash.
Old October 25th, 2018, 10:37 AM
  #18
silent_20's Avatar
I used Torque last night and the ambient temperature and intake temperature was exactly the same. I didn't have it running that long maybe a 30seconds. I wonder if its using the same sensor. I still haven't received my ambient sensor from Walmart.
Old October 25th, 2018, 4:12 PM
  #19
Twscarp's Avatar
Hi, here is my Torque display from today (2008 Express 1500 4.3l, 225K), the Air Temp and Intake are different, so it must have 2 sensors. I think my outside temp sensor is below the radiator somewhere, and assuming the Intake Air temp is on the intake ducting somewhere.
Old October 25th, 2018, 4:31 PM
  #20
silent_20's Avatar
Does your van display the ambient temperature on the DIC?
Quick Reply: Outside temp display?
