P0300 with no other code
#11
Thanks hanky. I will check mode 6 data as well. Looks like I should look at A2-A9(TID 0C)
Found this GM site containing Mode 6 specs and diagnostic parameters that might be helpful for others.
https://gsi.ext.gm.com/gmspo/mode6/index.html
if the misfire are accumulating on one bank...look for things common on one bank...02 sensor, compression.
The following 2 users liked this post by tech2:
Expresscv (March 18th, 2024),
mountainmanjoe (February 5th, 2021)
#12
Hello everyone,
New member here. I shamelessly signed up to get some help with an engine problem that stumped me. I wanted to see anyone with experience could give me some advice on this.
2004 Chevy Express Van 6L V8. I can feel misfires, and P0300 DTC. Just P0300 without specific cylinder number. I know this can be a tricky one.. I guess I am lucky. The vehicle was unregistered and sat for a year - shame. Cleared out old fuels and fresh fuel in.
Work done so far-
Identified bad spark plugs for two cylinders and replaced.(ACDelco) All fuel injectors(GM) replaced. After reset, for 250+ miles no issues, no pending codes, but Catalyst and EVAP Monitor wouldn't set after several drive cycles. Then, one morning, P0300 DTC showed pending, then triggered the P0300 and Engine Check light.
Observations at idle
Work done so far-
- Upstream O2 Sensors voltages look good and fluctuating. i.e. 0.285, 0.085
- MAF sensor reads 0.02 lb/s
- Short Term Fuel Trim looks good fluctuating between +-3% on bank 1, -4% on bank 2
- Long Term Fuel Trim high : 12.5% on bank 1, 16.5 on bank 2
- Haven't done vacuum test yet.
- Haven't done fuel pressure test yet
- Hard start sometimes
- P0300 DTC set and MIL lit
#14
Hello everyone,
Work done so far-
Work done so far-
KaylaBaby1141
December 23rd, 2020 11:38 AM
h2omusc
1988 - 1998 (GMT400)
July 27th, 2018 9:09 PM
Cole Bixler
April 20th, 2017 7:43 PM
