Pedal Commander anyone?
Old Oct 27, 2019 | 7:50 AM
cjm1973's Avatar
Default Pedal Commander anyone?
Had installed a Pedal Commander on my RAM 2500 and was very happy with the adjustable throttle response time. Upshifts were longer especially towing my 7600# trailer. My new 3500 6.0L passenger van seems to upshift quicker than I like. In manual mode, I can control the time in each gear until max RPM. But it's not very efficient as a driver. I would like the RPMs to say higher longer when accelerating from a stop. It will help with "towability". Anyone use a PC on these vans when towing?
Old Oct 27, 2019 | 8:03 AM
No. I just use the tow/haul switch and haven't had any issues.
Old Oct 27, 2019 | 10:03 PM
cjm1973's Avatar
What I've noticed is that in "tow haul" mode with these vans, transmission shift points are virtually the same as regular driving mode. These 1-2 shift point is very early on accelerations unless you mash the "go" pedal to the floor. Even then, it wants to shift way too early. The trans responds better in manual mode where you can hold rpms to redline (if needed) on inclines and aggressive acceleration. With my RAM 2500, "tow haul" changed those timings significantly and it helped big time when towing in the mountains.
With an upcoming trip next year to Alaska, I'm trying to find the right recipe. An engine/trans tune can be done. Unfortunately, I only have 2000 miles on the van and don't want to test a warranty claim against an aftermarket tune.
I may just go forward with PC and see how it behaves with the 6 speed and trailer in tow
damone
May 8, 2021 12:36 PM
stewie
Jul 20, 2015 11:16 AM
Renthorin
May 8, 2014 7:12 PM
Reaper22
10
Aug 5, 2012 10:00 PM
racerx55
May 17, 2007 8:05 AM
