Please advice on O2 sensors
#21
exhaust leaks can cause all sort of problems.
Your best solution is to have it professionally extracted and fixed.
Otherwise use a Kral repair kit.
the Brain (January 27th, 2023)
#22
Mountain man recommended the car wizard you tube and it is an excellent 32 minute read.
One of wizard s tips is using some huge long extensions to get at fittings too tight to access w a standard socket. One of the car wizard s tips was how to do that.
at 140$ an hour OP could buy some of the stuff the wizard recommends . Get that o 2 sensor out !,,
mountainmanjoe does this include power lose an crumie fuel mileage?
#23
Of course. The computer uses the O2 sensor to decide the fuel mixture.
the Brain (January 29th, 2023)
#24
all I know is what I learned from joining this forum and mountain man Joe and watching lots of you tubes. I did learn that I needed to have my own OBDII code reader (Actron 9630 $140. $) and to look at the DTC codes and freeze frames myself when a check engine CEL lite comes on instead of running to auto zone . (and buy my own chiltons and Haynes manuals, $19.99 for the 3500 engines from 99 to 2010. ) (PS - OP, my 3500 on an 07 chassis with roadtrek buildout to 9,000 #gets 13. mp g on regular gas. yours is getting 10??? )
The following 2 users liked this post by MitchM:
mountainmanjoe (January 29th, 2023),
#25
#26
AWD with VVT and I get about 12, so you're not far off.
Check your fuel trims.
the Brain (February 8th, 2023)
#27
will receive the exhaust clamps in a few days #7 which has 2 bolts broken doesn't show any black carbon around cylinder head unlike #8 I do see blackness.
besides the broken bolt haven't inspected #1 for blackness.
after I initially install the exhaust clamps (starting w/ #7 & #8) should I heat cycle engine then snug the clamp a few times?
thanks
#28
Any diagnostic tool should be able to provide fuel trims.
Heat cycling sounds like a good idea.
the Brain (February 15th, 2023)
#29
installed the clamps on cylinder 7 last week was kindof easy took longer to pull dog house back.
used blue medium lock tight.
#7 bolt that press's up to mannie is completley bottomed. accidently deleted image w/ take another next time I remove doghouse.
#8 was also easy had to trim the heat shield a tad, 8s bolt is much longer noway near being bottomed out,
saying installation was easy, I've gone an jinked myself so GM will get me back on #1. I'll have to lay on the rad core surport to reach in there for #1
#30
I don't think you need locktite there. It gets destroyed by heat anyway. Corrosion is a bigger issue. I would have used anti-seize.
That's not good. Bolts should never bottom out. I've seen people destroy blocks that way. Make sure you didn't mix them up.
