Power windows.
Old Feb 1, 2022 | 12:28 PM
Proline1988's Avatar
Default Power windows.
Hello all. New to this forum. Recently I bought a 2010 Chevy Express 1500 hi top conversion van by Explorer with 54,000 miles. The problem I am experiencing is with my power windows and backup camera. Its an intermittent problem. From time to time for no apparent reason neither front power windows will work. One day it works and all of a sudden it won't. Plus when my windows decide not to work I get a message on my backup camera that says service backup camera system. When I start the van up I put it in reverse to see what happens if the camera works my windows on driver and passenger side both work but if I get the service camera system neither side works. My mechanic had the van for 2 weeks and tried it everyday and of course they worked so he couldn't do anything till the problem arose. Is there anyone here ever experience this problem and how was it corrected. Thankyou you for any information that anyone can provide.
Last edited by Proline1988; Apr 7, 2023 at 5:58 PM. Reason: Corrections in spelling
Old Feb 1, 2022 | 2:02 PM
It could be faulty ground points.
Grab a schematic from gmupfitter.com and start tracing with a multimeter.
Old Feb 7, 2022 | 5:57 AM
TrishaB's Avatar
Originally Posted by Proline1988
Hello all. New to this forum. Recently I bought a 2010 Chevy Express 1500 hi top conversion van by Explorer with 54,000 miles. The problem I am experiencing is with my power windows and backup camera. Its an intermittent problem. From time to time for no apparent reason neither front power window will work. One day it works and all of a sudden it won't. Plus when my windows decide not to work I get a message on my backup camera that says service backup camera system. When I start the van up I put it in reverse to see what happens if the camera works my windows on driver and passenger side both work but if I get the service camera system neither side works. My mechanic had the van for 2 weeks and tried it everyday and of course they worked so he couldn't do anything till the problem arose. Is there anyone here ever experience this problem and how was it corrected. Thankyou you for any information that anyone can provide.
Hello. Sorry your having mechanical problems. They suck but are part of the process I guess. I know the hardest part is trusting someone to fix for the right price. I just went through something similar with my 1998 Express 1500. It turned out to the the motor which was close to $60 at the auto parts store. I first tried the regulator, which because of the year of my van was hard to find and I had to get from a salvage yard, that regulator came with a motor so I thought I had a "new motor". That did not work and then I tried a new switch which I bought on EBay and that did not work. People were telling me to get the wires tested because where the door opens and closes right by the front hinges there is wire running through to the door and that can get frayed. Others were saying I needed a brand new motor, not from a salvage yard and they were CORRECT. That fixed the problem. The hardest part about changing the motor is that the regulator is "riveted" to the door so its not like you can just unscrew to get to the motor housing. With all that said, the first thing I would check is the motor and secondly the switch and then if that doesn't work its probably your wires getting frayed. I hope this helps.
ChevyVanMan
Jan 29, 2025 11:56 AM
Ron DeGusipe
Sep 2, 2017 9:50 AM
biglg
Jan 27, 2017 10:58 AM
gunman
Apr 22, 2016 10:53 AM
jigstick
Jun 13, 2013 3:44 PM
