power windows and door locks
Hey guys I'm new here, first post. I have a 2003 express 3500 6.0 cargo van. 330xxx miles, blown motor. Recently bought a totalled 2006 3500 with 97xxx miles on it. Planning to swap the motor and trans into the 03. The 06 also has power locks and windows and was wondering if anyone has swapped these as well or knows if it is at all possible? Thanks in advance for any help
Can you swap the doors?....if not then you should be able to cut open a 06 door and copy all the parts over. Everything should bolt in, but you may have to buy or fabricate some connection points.
The wiring should be fairly easy too since the harness should be already there in your van tucked away somewhere.
From there, I would have an aftermarket alarm installed, then you can easily connect the door locks to the alarm for keyless entry.
if the 03 is a plain cargo van, then there most likely won't be any extra harnesses for the windows/doors/etc. I added cruise and power locks to mine and everything had to be done from scratch. There was nothing there already.
But I am sure it can be done, find the pinouts of all the wiring and wire it up yourself.
Mine is an '06.
It should be easy enough to swap the radio out, but I think you would need to have it programmed at the dealer to work in the other van. There are a bunch of "fixes" on the net showing how to get around this though. it involves tearing apart the radio and removing a little part inside. something like that.
i didn"t mean to scare you, you might have all the wiring there for the locks and windows. In my experience though, if it is a plain cargo van, the wiring won't be there. It is worth a look though.
Here are a couple things to try on the radio if you get there. Again, I don't know if it will fit, but I am *guessing* it will.
Unlock GM Theftlock Radio’s
Unlock Newer GM Theftlock Radio
sidewayzpimpin
June 12th, 2007 6:40 PM
cookie
July 7th, 2006 2:30 PM
