99 Tahoe Power Locks and Windows
Old May 7, 2007 | 11:35 PM
jmcash's Avatar
Default 99 Tahoe Power Locks and Windows
the power locks don't work on driver or passenger side and power window doesn't work on driver side...Any suggestion on where to start?????
Old May 8, 2007 | 1:44 AM
e's Avatar
e
Default RE: 99 Tahoe Power Locks and Windows
has the truck been wreck? or too your knowledge has anyone removed the drivers door? This would rule out broken wires in door jamb.
and or course check fuses, but sounds likeI would be looking moretowards the switch on the drivers side
Old May 8, 2007 | 2:37 PM
jmcash's Avatar
Not to my knowledge. I took the switch out to look for faulty wiring but didn't notice anything out of place. The locks still make a popping sound like they're getting power but they just don't move. They also work sometimes when its cold outside, however, I live in Texas and its rarely cold. What are the mechanical parts to power locks? Isn't there an actuator of some sorts? The window just went recently. I was told that it may be the switch or the motor. Is there anything else it could be?
Old May 8, 2007 | 4:28 PM
e's Avatar
e
if you can hear the motors popping i would say that the actuator has seen its better days. funny that both would crash at the same time. You can check at the actuator to see if your getting a full 12v. if they are they check to make sure the linkage is not binding.
superpainter
Nov 9, 2011 7:36 PM
hutchdjh
Colorado
Apr 11, 2010 4:07 PM
sidewayzpimpin
Jun 12, 2007 6:40 PM
n2whth2o
Nov 13, 2006 2:28 AM
cookie
Jul 7, 2006 2:30 PM
