Problem with the interior light!!
Old Jan 17, 2014 | 8:06 PM
Jet-Unit's Avatar
Default Problem with the interior light!!
Hi, when I bought the van, the Inside light was opening when the door open. I was working in the van and the light went off and never open again with the door but if I turn the switch on they open. Someone had this problem before???
Thanks for your help!!
Old Jan 17, 2014 | 8:09 PM
the trucks have a dome light off switch that over-rides the on signal. It is a separate switch from the dome on/off switch. It is part of the dimmer control...press the upper tab.
Old Jan 17, 2014 | 9:28 PM
canucklehead's Avatar
My override is a push button switch right below the headlight switch.....(2002)
Also the door pin could be sticking.....
Old Jan 17, 2014 | 11:09 PM
tsbrewers's Avatar
Mine acts goofy too, many times the dome light doesn't work, and many times the radio stays on even after I open a door. Mine is an '06. I haven't had a chance to work it out yet. But I have a feeling they are related to each other.
Old Jan 19, 2014 | 7:56 PM
greenfire's Avatar
Its the override switch...this is so when you are at a job site with the doors open all day you don't drain the battery.
Old Jan 22, 2014 | 9:21 AM
Jet-Unit's Avatar
Post
Hi, thanks everyone for your help. I look everything that you guys told me and nothing.
But I was installing the LED light in the cargo and when I toutch the wiring near the right back light, they open!!!! And now they work fine. The funniest thing is that I was installing those LED light because my dome light was not working, now I have LED light plus my dome!!! I think that I have enough light Inside!!!
Thanks again
Mike
paulg_ca
Oct 24, 2014 5:42 PM
nysmedic
May 13, 2013 10:04 PM
beckya99
Jul 12, 2011 12:29 PM
Christina
Nov 8, 2006 1:12 AM
KBX500
Nov 4, 2006 9:53 PM
