rear drum removal
Old Jul 1, 2019 | 7:22 AM
woodvette's Avatar
Default rear drum removal
hi. i have a 2002 express 3500, 13 inch rear drums, single wheel. need to check brakes. i am having a very hard time in getting off the drums. tried prying with screwdrivers, crow bars, made a puller with chain and jack. nothing is helping. i had them off once before and did not have this much trouble. anyone have trouble with theirs? i am guessing there is a ridge in the edge of the drum hanging up on the shoe preventing me from pulling it off. read i could grind off the shoe retaining pin from the back side and everything should release and fall off. wanted to get other opinions before i go that route. thanks.
Old Jul 1, 2019 | 11:00 AM
KChevy75's Avatar
It's been a while since I worked on drum brakes but they typically have a rubber plug covering a slot that you use to tighten the self adjuster. The drum will then come off.
They can also get stuck on the hub. A little penetrating spray, outward force and hammer taps will break it free of the hub.
Old Jul 1, 2019 | 1:06 PM
yup use the adjuster
Old Jul 2, 2019 | 10:05 AM
huntster's Avatar
If you have a slotted thick plate of steel ( i used a piece from a tire changer) you can use two bolts and pull the drum off as you tighten them up. Worked really well for me!
Old Jul 3, 2019 | 12:39 PM
StanVan's Avatar
15 Year Member
Release the parking brake! Caught my son doing this once.
What? It could happen.
Old Jul 3, 2019 | 10:34 PM
Beau Oszman's Avatar
Yup, release parking brake, fiddle with adjuster, if shoes are stuck against drum still, mallet on flat of drum.
