Rear leaf spring stud
2001 Chevy Express 3500 Cut Away. Mulling over replacing the rear leaf springs, this is an RV so there is plenty in the way. It appears the front of the rear leaf spring is held in place by a stud, not a bolt. Am I seeing this right?? Using mirrors there is not a bolt head on the other side!
jjrbus (January 26th, 2024)
Does it have a hex on the side with the threads? They make special installation tools that do all the work from one side. You just need a wrench for the nut so you can get a socket on the bolt. It might still be a bolt... just a "point drive" bolt.
jjrbus (January 27th, 2024)
It likely just has a round head on the other end with nothing holding it. Use the ratchet on the small hex to hold it, unthread the nut with a wrench, then it should just knock out.
jjrbus (January 28th, 2024)
You win the prize on this one! I have been all over the internet and read and checked parts lists every way I could think of and nothing. I can find no replacement bolt for this, only a standard hex head bolt so going to guess it is for manufacturing.
worst case you lose ten bucks?
