Regular Production Codes
#11
Nah, use the Park Solenoid. The Shift Lock. GM even recommends it.
https://dan.berladyn.online/gm/autom...-lock-control/
Maybe you would have to pull your power from there via a relay, rather than add to it as the schematic suggests, but I think I would look into this wire if I was doing what you were thinking.
#12
Here ya go. Fast idle ...
I find that the windshield ice scraper works really well for this. Also doubles as a brake bleeder buddy.
#13
I am not so sure that that is going to be "wife approved". Maybe try it out with your upcoming date to the island and let us know what she thinks.
#14
We will be putting a different kind of pedal to the metal. No vans on that trip.
#15
From reading the Bulletins, the Updates, I guess they UPDATE their descriptions which makes sense. This is what it states for AK5 four years later:
Air bags, frontal, driver and right-front passenger
1 - Includes passenger-side air bag deactivation switch. Included with (ZX2) driver and front passenger high-back bucket seats or (ZP6) 5-passenger Savana Crew Van Package. Not available with (ZX1) driver only high-back bucket seat or (AJ3) driver-side only front
I am going to believe that it is simply because I have C99, which is probably from some form of Cargo option/modification package to the standard package.
#17
I wonder what is on the passenger side if you just have this AJ3 code:
Air bag, frontal, driver-side only (deletes passenger-side)
1 - Included and only available with (ZX1) driver-only high-back bucket seat. Not available with (ZX2) driver and front passenger high-back bucket seats or (ZP6) 5-passenger Savana Crew Van Package. NOTE: Passenger seat is removed when ordered and cannot be added back in. Always use safety belts and the correct child restraints. Children are safer when properly secured in a rear seat in the appropriate child restraint. See the Owner's Manual for more information.
Do they put an airbag-less panel in there or is it simply not connected? I kind of wish I had that option (for the insurance bureaucracy) because then I could build a glovebox. It is probably only an RPO code for those transit vans where they remove the passenger door and install a third party body all the way up into the cab. No seat. That's definitely what that is.
